Forum: ARM programming with GCC/GNU tools Keil -> GNU porting linker errors
von Randall Aiken (Guest)
I'm porting some existing functional Keil code over to the GNU compiler,
and I'm running into some odd linker errors.  The code compiles fine,
but I get the linker errors listed below.  They look like they refer to
library functions, so I suspect I may not have all the "#include" files
I need.  Any ideas?
Thanks,
Randall Aiken
Linker error output:
Linking: moat.elf
arm-elf-gcc  -mcpu=arm7tdmi  -I. -gdwarf-2 -DROM_RUN  -Os -Wall
-Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch
-Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=crt0.lst
-MD -MP -MF .dep/moat.elf.d crt0.o    main.o CLI.o I2C.o ISR.o Serial.o
SPI.o     --output moat.elf -nostartfiles -Wl,-Map=moat.map,--cref -lc
-lm -lc -lgcc -TLPC2124-ROM.ld
c:/winarm/bin/../lib/gcc/arm-elf/4.1.0/../../../../arm-elf/lib\libc.a(fr
eer.o):
In function `_malloc_trim_r':mallocr.c:(.text+0x48): undefined reference
to `_sbrk_r'
:mallocr.c:(.text+0x64): undefined reference to `_sbrk_r'
:mallocr.c:(.text+0x84): undefined reference to `_sbrk_r'
c:/winarm/bin/../lib/gcc/arm-elf/4.1.0/../../../../arm-elf/lib\libc.a(ma
kebuf.o):
In function `__smakebuf':makebuf.c:(.text+0x3c): undefined reference to
`_fstat_r'
:makebuf.c:(.text+0x110): undefined reference to `isatty'
llocr.o):
In function `_malloc_r':mallocr.c:(.text+0x424): undefined reference to
`_sbrk_r'
:mallocr.c:(.text+0x4cc): undefined reference to `_sbrk_r'
c:/winarm/bin/../lib/gcc/arm-elf/4.1.0/../../../../arm-elf/lib\libc.a(st
dio.o):
In function `__sclose':stdio.c:(.text+0xc): undefined reference to
`_close_r'
dio.o):
In function `__sseek':stdio.c:(.text+0x30): undefined reference to
`_lseek_r'
dio.o):
In function `__swrite':stdio.c:(.text+0x84): undefined reference to
`_lseek_r'
:stdio.c:(.text+0xac): undefined reference to `_write_r'
dio.o):
In function `__sread':stdio.c:(.text+0xd0): undefined reference to
`_read_r'
Make: *** [moat.elf] Error 1
von Andreas S. (andreas) (Admin)
Randall Aiken wrote:
> c:/winarm/bin/../lib/gcc/arm-elf/4.1.0/../../../../arm-elf/lib\libc.a(fr eer.o):
> to `_sbrk_r'
You need to provide your own implementation of the Newlib stubs (_*_r).
See syscalls.c in the example projects.
Thanks!  I've got it all working now.  I had to modify the syscalls
examples to work with my UART character read/writes, but that wasn't too
difficult.
Randall Aiken
