Forum: ARM programming with GCC/GNU tools C++ Linker Problem
von Matthias Wilde (Guest)
Hello,
I use NutOS (see http://www.ethernut.de) and using C++. They provide
linker scripts but I have problems using linking C++ objects. Linker
Script is the following. To be honest, I have no idea of linker scripts,
this one is used:
http://cvs.sourceforge.net/viewcvs.py/ethernut/nut/arch/arm/ldscripts/at91_ram.ld?rev=1.1&view=markup
I get the following error message:
winarm\bin\..\lib\gcc\arm-elf\4.0.2\..\..\..\..\arm-elf\bin\ld.exe:
error: no
memory region specified for loadable section
`.gnu.linkonce.t._ZN15TemplateCoun
erIhEC2Ev'
Any hints are welcome.
Thank you in advance
Matthias
von Martin Thomas (Guest)
> this one is used:
> error: no
> erIhEC2Ev'
The linker-script from the ethernet-cvs seems to be a "c-only" script. I
have some ideas about what has to be added/changed (i.e. the
linkonce-entries and ctor/dtor-sections and data) but currently no time
to create a modified version. Maybe later today or tomorrow. The
startup-code has to be modified too to call the ctors before "branch to
main()".
Martin Thomas
Hi Martin,
yes, you are right, it is running for C. However I tried to expand the
script for C++, but as I said I have no idea how. However, if you could
insert the missing parts that would be great. Or if you could just give
me some hintswhere I can get information or an example how a C++ linker
script should look like - that would be also very helpful.
Thank you very much
Matthias
> main()".
> Martin Thomas
Hello again,
I think I can solve it, I just looked for the linker default script. I
try tonight and let you know.
Matthias
Ok, after two nights, I could not solve the problem. Now I get unresoved
functions of NutOS. To be honest, linker scripts are more complicated
than I expected.....
I have to wait for an expert ....
Best regards
Matthias
I have modified the ethernut/NutOS-Linker-Script. Completly untested but
should give an idea. The script will be available for some days on:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/winarmtests/
> Now I get unresoved functions of NutOS.
Maybe a "C/C++" symbol-name problem here. As far as I know the NutOS
header-files do not include an extern "C"-Wrapper like
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
At least I do not see them in the few headers files which I have read in
the CVS. Without this "wrappter" there will be unresolved externals when
the NutOS-libraries are compiled with the C-compiler and the user
program is compiled with the C++-compiler.
For a test you could try
extern "C" {
#include "a_NutOS_include_file.h"
#include "another_NutOS_include_file.h"
in your C++ source-files.
Hope this helps
Martin Thomas
Hello Martin,
thnak you very much for the linker script. I will test it end of this
week. The extern "C" problem I know and I allready included the header
files like you recommended. However, might be an other issue. I try your
linker script and let you know the results.
Best regards
Matthias
Hello Martin,
Ok I promised a several weeks ago "I will test it end of the week".....
I tested it now and your suggestion works for me perfect.
THANK YOU VERY MUCH!!
One last question. Can we use your additional changes without any
restrictions / copyright issues within Nut/OS?
Best regards
Matthias
> Hello Martin,
I'm glad that I could help you.
I have got my information from the sources given in the modified
linker-script and a little "try and error" with my gcc-C++-test on the
LPC2000. I don't think that there are any restrictions or
copyright-issues since "it's just the way it has to be done". It would
be nice if you or Harald could keep my name somewhere in the header of
the file.
Martin Thomas
