Forum: ARM programming with GCC/GNU tools Z8: SPI interrupt does not work
von Bruno (Guest)
All others interrupts work in Z8, but the SPI interrupt does not work..
Somebody knows what can be happening???
von Clifford S. (clifford)
This an an ARM related forum. Perhaps you should be at
http://www.z8micro.com/forum/.
Either way, you will probably need to specify the exact Z8 part you are
using, and include an example the code you are using to initialise the
interface. Whether you are using the SPI as a master or slave is also
pertinent, and if it is a slave, are you sure the master is producing a
valid signal?
Clifford
