Forum: ARM programming with GCC/GNU tools Linker problems while moving C to C++
von Cem Eryasar (Guest)
I am using WinARM-20060117-1 with gcc 4.0.2.
I successfuly compiled my first program written in pure C.
After then I started to port my funtions into object oriented style
using C++. However after several compile and fix loops it seems that
I stuck into a linker problem on low level functions:
c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libg.a(ma
llocr.o):
In function `_malloc_r':mallocr.c:(.text+0x430): undefined reference to
`_sbrk_r'
:mallocr.c:(.text+0x5ec): undefined reference to `_sbrk_r'
c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libg.a(fr
eer.o):
In function `_malloc_trim_r':mallocr.c:(.text+0x48): undefined reference
to `_sbrk_r'
:mallocr.c:(.text+0x70): undefined reference to `_sbrk_r'
:mallocr.c:(.text+0xb4): undefined reference to `_sbrk_r'
kebuf.o):
In function `__smakebuf':makebuf.c:(.text+0x44): undefined reference to
`_fstat_r'
:makebuf.c:(.text+0xe4): undefined reference to `isatty'
c:/winarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib\libg.a(st
dio.o):
In function `__sread':stdio.c:(.text+0x1c): undefined reference to
`_read_r'
dio.o):
In function `__swrite':stdio.c:(.text+0x78): undefined reference to
`_lseek_r'
:stdio.c:(.text+0x9c): undefined reference to `_write_r'
dio.o):
In function `__sseek':stdio.c:(.text+0xc0): undefined reference to
`_lseek_r'
dio.o):
In function `__sclose':stdio.c:(.text+0xf8): undefined reference to
`_close_r'
make.exe: *** [main.elf] Error 1
Is this specific to C++?
Isn't WinARM intended to be used with C++?
How can I solve this problem?
Thanks alot
Regards
Cem Eryasar
von Clifford S. (clifford)
All of the 'undefined references' are functions from the Newlib C
library 'system calls' layer. They are specific to the target platform
and must be provided by you, (support for some targets is provided with
WinARM). This is not specific C++, you need these functions for C code
also, so if it worked for your C code, then you must have omitted the
required object code from the C++ link.
Compare your C link log with your C++ log. Post the logs if you can't
see the problem.
I can assure you that WinARM supports C++ - I have built a 600Kb C++
application using it. Being an in-house board and an unsupported chip, I
had to provide the syscalls myself - I hope you are luckier!
Clifford
Thanks for the reply!
I am using a Philips LPC-2138 based board. Is this CPU amongst the
supported ones? I can see that there are several example projects for
Philips LPC chips within the WinARM directory. Where should I look at to
find that out?
Cem
> WinARM).
von Martin Thomas (Guest)
> find that out?
There is an example for an LPC2138 in the "example-collection" from
where you can copy the linker-skript and startup-code. You can use a
copy of the syscalls.c from another LPC-example or link with the
newlib-lpc (libnewlib-lpc.a) for the newlib-syscalls. There are examples
for both methods.
Thanks a lot Martin for the pointers.
Btw, is there any document telling the inner dynamics of this linking
issue and syscalls stuff? Before I go back into hacking loop I'd like to
read some basics if possible...
Cem
>> find that out?
> for both methods.
Yes. The Newlib manual, in the doc folder, or online
http://sources.redhat.com/newlib/libc.html#SEC195
Clifford
