Forum: ARM programming with GCC/GNU tools SPI slave ISR problem
Author: V. B. (bray)
I have problem with SPI slave...and i think it is GCC interrupt problem
because it works in Keil.  :(
SPI ISR fires only once (on first SSEL0 toggle to low) and then
stops...main loop is running ok.
Is something wrong with interrupts or ISR routine?
this is my SPI init...
unsigned long spi0Init(void)
   S0SPCR = 0x00;
   PINSEL0 &= 0xFFFF00FF;
   PINSEL0 |= 0x00005500;
   S0SPCR = SPI0_SPIE;
   VICIntSelect &= ~VIC_BIT(VIC_SPI0);  // UART0 selected as IRQ
   VICIntEnable = VIC_BIT(VIC_SPI0);    // UART0 interrupt enabled
   VICVectCntl8 = VIC_ENABLE | VIC_SPI0;
   VICVectAddr8 = (uint32_t)spi0ISR;    // address of the ISR
   return (S0SPSR & 0x08);
..and ISR
void _attribute_ ((interrupt("IRQ"))) spi0ISR(void);
void spi0ISR(void)
 DWORD regValue;
 static unsigned char cnt=0;
 S0SPINT = 0x0000001;        /* clear interrupt flag */
 ISR_ENTRY();
 regValue = S0SPSR;
 spi_tmpcnt++;
 spi_in[cnt] = S0SPDR;
 S0SPDR = spi_out[cnt];
 if (++cnt>SPI_BUFFER-1) cnt=0;
 ISR_EXIT();                           // recover registers and return
 VICVectAddr = 0x00000000;             // clear this interrupt from the
VIC
