Forum: ARM programming with GCC/GNU tools ARM programming
von Gladson N. (gladson)
HI
I am new to this type of embedded system programming and am using the
AT91 evaluation board.I am looking for simply C/C++ codes to test.I need
to get a feel and be commfortable with the hardware before attempting to
implement my project.
Thanx
Gladson
von Martin Thomas (Guest)
Gladson Ncanana wrote:
> HI
> Thanx
> Gladson
There are a lot of AT91 evaluation-boards available and you do not even
mention which AT91 is mounted. Without further information it's
difficult to help.
von Bill (Guest)
>> HI
>> Thanx
>> Gladson
> difficult to help.
Martin's right, there ARE a lot of developement boards out there.
I am also new to ARM. I have the AT91SAM7S-EK development board, which
contains the AT91SAM7S64 part. I also have the J-Link-ARM-IAR
jtag-to-USB converter for debug. I would really like to learn to use the
GCC developement environment.
I would like to set up a development environment, and then:
1. flash an led to make sure I got the environment right
2. use USB Mass Storage Device class to work
3. Implement a FAT16 file system
After I do this, I will have my own memory stick.
How do I get started?
Bill
von gladson (Guest)
>> HI
>> Thanx
>> Gladson
> difficult to help.
'Sorry guys it's a AT91EB40 board and a reference site where I can get
examples will be appreciated'
von gladson (Guest)
>> HI
>> Thanx
>> Gladson
> difficult to help.
'Sorry guys it'sa AT91EB40 evaluation board'
>>> HI
>>> Thanx
>>> Gladson
>> difficult to help.
Did you check at91.com->kit? At least for the SAM7s Atmel provides
examples there. The AT91R4000-series is supported by open-source FTOSes
like ecos and FreeRTOS too. IRC the ARM-port of ethernut is also based
on this controller. Basicly you need a linker-script and startup-code
which should be available in the projects.
Martin Thomas
