Forum: ARM programming with GCC/GNU tools Problem with the basicusb example
von ralawa (Guest)
I am trying the basicusb example provided with the winarm toolchain. I
use it as a virtual com port, so it is supposed to do a bridge between
the USART0 and the virtual port. I have one problem with it. When I send
datas from virtual port to usart0 it works fine but when I send datas
from the usart0 I only receive one character from the virtual com port.
After that, nothing works.
Have you a idea about this issue?
Thank you,
Eric
von Martin Thomas (Guest)
ralawa wrote:
> Hi,
I have only ported this example to gcc. I have not teste the port very
much but the bi-directional data-exchange did work. But maybe there is a
mistake in the port. Get the evaluation-version of the IAR-Compiler and
the original source-code from at91.com and try again. If you see the
problem with this setup too ask in the forum at at91.com. You can also
try the USB-code in the freertos example available from freertos.org.
Martin Thomas
von Mh T. (lpc2103)
Having same problem when I ported the Atmel USB
Virtual COM example to C8051F320 quite long ago.
But sorry, could not recall what went wrong.
I think it is related to:
- ACM Descriptor, or
- have to keep returning NAK to PC if microcontroller
  has no serial data to send.
I also think it is easier to get original source
von ralawa (Guest)
OK I will try this.
Thank you.
