Forum: ARM programming with GCC/GNU tools Some basic questions (coming from WinAVR)
von phil (Guest)
First, thank-you Martin Thomas for putting together this great
collection of tools for the ARM.  Thanks to your examples I quickly had
an LED blinking on my hardware.
I've done quite a bit of embedded programming but I'm not very familiar
with the GCC compilation process.  I've been using WinAVR for a while
now and so most of my questions are about the differences between WinAVR
and WinARM.  From my understanding, when you start a new WinARM project
you need to provide a startup file (crt0.S) and a linker script (such as
LPC2106-ROM.ld), in addition to the makefile, source, and header files.
How do the startup file and linker script differ from processor to
processor or from project to project?
In particular, I want to create a project using the LPC2103.  Can I just
copy the LPC2106-ROM.ld script and change the memory sizes to match the
LPC2103 or is there more involved?
Do I need to make any changes to the crt0.S file to make it work for
this new processor?  Do I need to make changes to this file to use
various interrupts?
Thanks for the help,
Phil
von Martin Thomas (Guest)
I'm glad that the collection is useful for you.
Usualy they just differ from processor/target to target. Sometimes I
have modified startup and linker-skripts for special tasks but for the
beginning it should be ok to copy the files from the examples.
I do not own a LPC2103, adapting the memory-sizes might be enough but
I'm not sure.
> various interrupts?
I don't think that you need to change the startup-code in terms for
interrupt-handling, but you will see different approaches. Some
developers use "interrupt wrappers" to call ISR others use macros inside
ISRs. I currently don't remember of a "wrapper"-example for LPC is in
the examples-directory. But there is one for AT91SAM7S which can be used
too. The basic ARM7-interupt handling is the same for LPC and AT91SAM.
Just pick a small LPC-"blink"-example, change the memory-sections and
give it a try. Describe the errors if it does not work.
Hope this helps,
Martin Thomas
