Forum: ARM programming with GCC/GNU tools Problem compiling arm-elf gcc-4.1.0 von Debian and Cygnus
Author: Christoph Bayer (Guest)
I compild and installed binutils as descriped in the ARM-GCC forum
without problems. But building gcc-4.1.0 breaks with the following
error:
/root/buildgcc/./gcc/xgcc -B/root/buildgcc/./gcc/ -B//bin/ -B//lib/
-isystem //include -isystem //sys-include -c -DHAVE_CONFIG_H -O2 -g -O2
-I. -I../../../gcc-4.1.0/libiberty/../include  -W -Wall -pedantic
-Wwrite-strings -Wstrict-prototypes
../../../gcc-4.1.0/libiberty/strsignal.c -o strsignal.o
../../../gcc-4.1.0/libiberty/strsignal.c:553: error: conflicting types
for 'psignal'
/usr/include/signal.h:141: error: previous declaration of 'psignal' was
here
../../../gcc-4.1.0/libiberty/strsignal.c: In function 'psignal':
../../../gcc-4.1.0/libiberty/strsignal.c:558: warning: comparison
between signed and unsigned
make[2]: *** [strsignal.o] Error 1
make[2]: Leaving directory `/root/buildgcc/i686-pc-linux-gnu/libiberty'
make[1]: *** [all-target-libiberty] Error 2
make[1]: Leaving directory `/root/buildgcc'
make: *** [all] Error 2
This was the command:
beta:~/buildgcc# ../gcc-4.1.0/configure --prefix=$PREFIX
--target=$TARGET --enable-interwork --enable-multilib
--enable-languages=c --without-headers --with-newlib
Thanks in advance!
Best regards,
Christoph
Author: Andreas Schwarz (andreas) (Admin) Flattr this
> error:
What Debian release are you using? I didn't have any problems building
4.1.0 on Sarge.
Author: mthomas (Guest)
This might be a problem with the binutils and the configuration of the
binutils. IRC there is some documented problem with the libiberty and
the parameters of strsignal on other platforms and a patch for this i.e.
in crosstool. So far I have not seen this issue when building the WinARM
components with MinGW/minsys (up to 4.0.2). This might not help in the
first place but you may check the binutils Version and
configuration-options again. It there a special reason for
"--without-headers"?
Martin Thomas
I have checked again and realized that in this run I have forgotten to
set the prefix and target variables... Shame on me!
I tried again with the correct target but it breaks again (only c now):
Configuring in arm-elf/libssp
configure: creating cache ./config.cache
checking build system type... i686-pc-linux-gnu
checking host system type... arm-unknown-elf
checking target system type... arm-unknown-elf
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for arm-elf-strip... arm-elf-strip
checking for --enable-version-specific-runtime-libs... no
checking whether to enable maintainer-specific portions of Makefiles...
no
checking for arm-elf-gcc... /root/gcc-arm/./gcc/xgcc
-B/root/gcc-arm/./gcc/ -B/usr/local/arm/arm-elf/bin/
-B/usr/local/arm/arm-elf/lib/ -isystem /usr/local/arm/arm-elf/include
-isystem /usr/local/arm/arm-elf/sys-include
checking for C compiler default output file name... configure: error: C
compiler cannot create executables
See `config.log' for more details.
make[1]: *** [configure-target-libssp] Error 1
make[1]: Leaving directory `/root/gcc-arm'
I had no problems building binutils and gcc for target=host, I used this
new compiler in the last try building the arm stuff, but makes no change
compared to the 4.0.2 version of the compiler...
> 4.1.0 on Sarge.
I am using sid with gcc version 4.0.2.
mthomas wrote:
> It there a special reason for "--without-headers"?
Not really, I googled a little bit and found this options set in some
examples for building a cross compiler, as far as I remember it shoud be
a workaround for a bug in gcc-3.4.3... I just gave it a try ;-)
Good idee :-)
This is the reason:
configure:2310: /root/gcc-arm/./gcc/xgcc -B/root/gcc-arm/./gcc/
-B/usr/local/arm/arm-elf/bin/ -B/usr/local/arm/arm-elf/lib/ -isystem
/usr/local/arm/arm-elf/include -isystem
/usr/local/arm/arm-elf/sys-include -O2 -g -O2    conftest.c  >&5
/usr/local/arm/bin/arm-elf-ld: crt0.o: No such file: No such file or
directory
Looks like gcc needs the newlib lib, which needs gcc to be build :-)
Any other idee than using a prebuild gcc to first build newlib and than
build
the new gcc?
I am now able to successfully build gcc for plain C by adding
"--disable-libssp" to the configuration line.
But I am still unable to compile the C++ compiler.
It seems like the build process tries to build the
libssp (for C if no --disable-libssp is given) and
libstdc++ (for C++ which I can not stop...).
What is interesting, at some point the build process tells me
that libstdcc++ is not supported for that platform
(what a surprise...).
Does anyboday have an idee whats going wrong here?
