Forum: µC & Digital Electronics SD card lock and unlock
von Al pacino D. (bigmicro)
Hello guys,
I got my SD card software working fine, but now I have a problem with
locking a SD card programmaticaly. I use the command CMD42 to set a
password and to lock and unlock. I've tried several times, but nothing
seems to happen. Everything seems to work, but it's like just nothing
happens.
So I was wondering if you guys managed to lock the card with CMD42 (not
the mechanical switch lock). If you did it, would you please post the
piece of code here? I hope this feature is not limited, because of not
having a license for it.
I use the following hardware:
SD-micro of 1GB, normal SD of 1GB
ARM microcontroller (AT91SAM7A3)
IAR 4.41 Compiler.
Thank you very much.
von Mike (Guest)
According to SD card specification CMD42 is an optional optional and may
not be implemented by all manufacturers. What card are you using?
von Mike (Guest)
Toshiba states under CMD42:
"CMD42 LOCK_UNLOCK - Card Lock/Unlock Function is not implemented."
So if your card is from Toshiba it would not work. Sandisk, however
seems to support CMD42
Best regards
Mike
von Termite (Guest)
The CMD42 is optional in Version 1.01 and 1.10 and mandatory from
Version 2.00.
Thanks for your responses my friends,
I use only Sandisk cards (I use microSD which belongs to Version 2.00
and higer) but that seems not to work. Also I can't find any software
for WinXP to do a software lock based on password for those SD cards,
just to make sure that it works.
It's realy strange that there is almost no information about it except
in the Sandisk documentation (which is very limited to text only).
Hope someone can tell me more about it.
von Termite (Guest)
Ther are some informations to the SD-card commands on
http://www.sdcard.org/about/memory_card/pls/
see 4.3.7 Card Lock/Unlock Operation
have you checked Card Status after sendig the command? perhaps ther are
some information wat is going wrong.
see 4.10.1 Card Status for more information
Hi Termite,
I already have done that, that's how I managed to read/write SDHC cards.
That's why it's a real problem to me, because using the documentation is
the only information I have about lock/unlock the SD card. It's a bit
confusing...
Please if someone else implement the lock/unlock piece, please share
with me the source, or at least what things should I do. Cause it
doesn't work accoording to the Simplify spec doc from Sandisk.
Thank you.
von Termite (Guest)
Please check the card State after sending the lock comand.
After locking a card you have to unplug the card to check if the lock is
working.
please check if you are in the correct state to send the command. You
can see it in the card state.
please check block length and paswort length. you know that you have to
send the compleat block length (2^n) data for the command? you have to
set block length befor sending the command data. and you have to send as
many data you have specified in block length. non used data can be
filled with dummy byts.
Thanks Termite,
Ok, there can be several reasons why it couldn't work.
Like you said, the length of datablok. I just used 4 bytes, one is for
mode, one is for passwordlen and two for the password. I used as
password: 0xAAAA.
But I also include 2 bytes of CRC16 value, but set datablock length is
just 4 bytes. I get no error, the response of CMD42 =
0b00000000000000000000100100000000
When I ask the card for the card-status I get:
0b00000000000000000000110100000000
Another reason could be that I switched off CRC check at the very
beginning, while CMD42 uses CRC16 on the dataline.
Hello,
Has anyone tried the software lock/unlock command (CMD42) succesfully?
Because I don't, and I'm so tired and stressed of waisting my boss's
time.
I've tried everything, but that damned command is not working for me.
I realy hope someone can give me a golden tip.
Thank you.
Hello guys,
I recently tried to get lock/unlock the SD card again, but with no
succes.
So is there anybody who got the lock/unlock working for the SD card?
I've searched the whole web, read SD documentation again and again with
another guy from my work, but I still can't manage to get it work. Also
it seems there is nobody on this planet who manages to lock an SD card
with a password and than unlock it again. Even Linux or Windows don't
have the possibility to protect the SD card with lock command. Also
there is no software that can do that, even commercial ones.
So I seriously doubt wether CMD42 (lock/unlock) is actually working. So
I dare to challenge really good embedded experts that they can't get the
CMD42 working. So experts, prove me I'm totally wrong, I really offer
you to disgrace me as much as you can.
Thank you.
von 135790 1. (Company: 246810) (chairang)
HI
I tested the lock/unlock function ,and it worked.
I used to want to help you ,but I'am an Chinese and I don't understand
German-language, I tryed to login, but don't know how to login.
Today while I try again, I find it's in English, my English is poor, but
I know some simple words.
At first you should check out whether your SD card support lock/unlock.
I have three SD cards tested, two from panasonic(32MB) and one from
kingston(2GB),it seems the old panasonic card does not support this
function, and the new kongston SD works well.
You can use a mobile phone to check it. I don't know why Windows doesn't
support, but my Linux phone(MOTO E6)supports. If the SD card support,
you would see a "password protection".
I use the MOTO E6 to lock my card, and use STM32F103VBT6 to unlock, then
use STM32 to lock and E6 to unlock, both works well.
I use the SPI mode.
If I cound help you, please email chairang<at>126.com
von Asif (Guest)
Yes
